SOURCE: Blue screen on HP WLAN MultiPort W200
Rollback the W200 driver to version 1.00C. Subsequent drivers are incompatible with XP SP2.
Unfortunately, WPA support came in version 1.00E, so W200 + XpSp2 = no WPA support. :(
SOURCE: Wlan W200 connection problem
There is a solution to this, and you won't have to buy a new card. The folks at HP, however smart in their design of this laptop, have not properly updated the bug fix for the wlan w200 drivers. What you'll need to do is actually take back your network adapter driver all the way back to Version 1.0 revision C. I did this with an n610c that I got for free because it was BSOD'ing every time the wireless was turned on. For the most part the wireless can handle older routers and wlan areas, but will BSOD when within range of a wireless "N" adapter. Simply download the driver version 1.0c and you should have no more issues.
Tip: You can disable the card manually by pressing your "Fn + F2" keys, rather than trying to navigate your menus before getting the BSOD.
SOURCE: WLAN Multiport W200 not connecting to wireless network
Anyone who has this problem: the problem is with the W200 driver that HPclaims you should use. Download this driver instead and your problems should be fixed:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en
SOURCE: Since I did a clean install of my OS can not
jeffrundall
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
