When we turn the TV on get a ghost picture of program I'm watching. It looks like a 3D picturewith no glasses.
SOURCE: i have all proper 3d
make sure the left right buttond on remote are set right or it looks like glasses are not working it is the blue button i think, i have the lg 47lx6500 and i had the same thing happen to me.
SOURCE: my hitachi ld328700 lcd tv picture has gone faulty
ALL LCD/Plasma televisions have adjustment for convergence, RGB drive,
color saturation and a virtual host of other parameters than can be
adjusted through the "technician's service menu".
Unfortunately, you are not supplied with the information to access that
menu and you're limited to a "user's menu" which allows you to only
adjust some of the basics, like volume, tone, color, tint and several
more.
Methods of access vary from manufacturer to
manufacturer. And the main reason that a consumer isn't given access to
these menus is simply because they can totally screw up a set with just
the push of a button, requiring hours to correct by a qualified
technician.
Of course, most all of them have a factory
default to recover most of the settings, but there's still a lot of
finite settings that would have to be adjusted to get your TV looking
right again.
Depending on the LCD manufacturer, it may be
adjustable for your specific set, or you could have a problem with the
LCD digital or driver modules. Even the LCD display itself could be
failing.
Best bet is to call a QAUALIFIED technician and have
it checked out. If you don't have an extended service plan from where
you purchased the set, or if it's out of manufacturer's warranty, some
of the repairs could be quite expensive. enough so that it may be worth
looking into buying a replacement set.
SOURCE: screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
SOURCE: my tv turns on u can watch it for about 5 mins
Sounds like bad capacitors on the power supply board. Locate power supply board, remove it carefully and check capacitors on an esr meter.
SOURCE: Bad picture
Ur convergence is dead,U know how to solder?Buy a convergence kit.Use what in that kit.Websites have it.Tv Repair World.com,Ebay.com.
