When I start the bike I put it into gear the engine light comes on and the engine dies
SOURCE: Front sprocket
Hi ........... One tooth less will give you more top speed (if you can pull top revs) but will reduce accelleration. If you go for one tooth less you'll need to tighten the chain and/or remove a link. It's a trade off ............ decide what you want the bike to do.
SOURCE: '95 Yamaha YZ 125 clutch - stays in gear when clutch is pulled in
hey dude,, just thought id come in and give u some tips or 3,, i take it when u pull clutch lever in, and try and change gear it feels like your foot will snap b4 it goes in gear,, if that makes sense,, firstly mate,is to make sure the clutch cable slides freely ,easest way is to take cable off and just grab 1 end and make sure it isnt sticky,, if so dip one end of the cable in a bit of old oil ,,whilst holdin the other end ,pull and push the cable inner, this will **** up a bit of lubricant inside the cable ,, keep doin this each end till free to move, ,,next step if the cables ok,,, and may need help if u dont no,drain the oil out,,and as u r sat on the bike is to remove the clutch casing on the right hand side of the moter,where the bottom end of the cable goes,remove the casing being carefull not damage the gasket,,then u will see clutch plates and friction plates housed,, undo the 7 or 8 spring loaded bolts carefully take the first fibre plate out then metal friction plate then another fibre plate and so on,, wen u take the 1st plate out place that on the bench ,stacking each plate on top of one another, cause they have to go back in as they came out,,wen out,,u need a piece of wet n dry paper ,or fine emery,,and just wipe round both sides of the fibre plates taking the shine off them,as u put them back in,, put casing back on with a decent gasket,, oil back in cable on, make sure cable has no free play on the lever so wen u r about to pull lever in it bite straight away,, start her up, warm it up and try it,,any probs still il eat my shoe,, take care m8
SOURCE: dies when put into gear 2000 Yamaha DT 125 R
SOUNDS LIKE IT COULD BE THE SAFETY SWITCH FOR THE KICK STAND ,IF THE SWITCH HAS BEEN DAMAGED IT WILL START UP FINE AND WHEN PUT IN TO GEAR AND CLUTCH IS RELEASED IT WILL DIE.(This is a safety feature)
If that don't fix,Please post back
Please rate this fixya solution
SOURCE: I HAVE AN OLD YAMAHA SR 125 ITS REVS GO UP AND
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Since you mentioned uneven idle revs, be sure the carb and manifold are on tight and also tighten the cylinder and head. Air leaks can screw up the idle.
Please rate this solution. Thanks speedfreak41
SOURCE: I have an 03 Honda 750 Shadow. I start the bike in
Your kickstand switch is either broken or out of position. The bike kills the engine as a safety feature if it thinks the sidestand is down and the bike is put in gear while the engine is running.
