Well i reinstalled windows and now i cant even go online because the Ethernet driver is not installed i can't find it on dell site can someone help me please
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Considering one of the drivers you need is the ethernet controller, you will not have access to the internet. After you download the neccessary drivers from a different computer, you can burn them to cd or put them on a flash drive to transfer them to the dell.
More than likely it is your ethernet card that is bad. It will be easier to buy an ethernet card and install. The procedure is not hard. You will need to open your computer and sit the card in one of the open slots toward the back of the computer.
It seems that after re-installing windows you have missed the Driver installation for your hardware. If you have a disk (which reads Drivers and Utilities) that came with your computer, You can insert it in your CD Driver and select the Driver for Network adapter. If you do not have a disc, you can always visit the Dell's support site i.e.:support.dell.com and Get the drivers suitable for your hardware by selecting the model or Entering the Service Tag of your Dell computer.
Almost the exact same problem. New 4350d Canon printer trying to connect it with Dell 8300 with XP. The computer says it does not recognize. Tried everything - reinstall drivers, download drivers, tried every USB port, swapped cables, spoke with Canon support and finally took the printer back and got a new one (Canon support person decided the USB board must be bad). New machine - same old problem.
Im not sure if you are asking for the E310 drivers or the 4600c drivers, so I'm sending you the link to download drivers for both the systems. http://tinyurl.com/2jpgqs (Thats for E310)
yes it was i actually found the file last night.. thanks though :)
i hope this helps others out too
