During the Start Automatic gear does not change from Park position to any other position. I can operate the gear by relising the mechanical lock and moving the gear to position N (by inserting the key in to the hole infront of the gear handle). The car drives fine with no other problems. When I stop the car I can move the gear to the park position. Once I move the gear to Park position I can not move the gear, it locks.
Look forward to hear from you
Best regards
Halil
The ignition switch is turned to the RUN or the START position.
When the ignition switch is in the RUN or the START position, the current flows from the B/U Lamp fuse located in the underhood bussed electrical center (UBEC) through CKT 839 (PNK) to the park/neutral position switch. The park/neutral position switch also feeds the backup lamps portion of the switch. With the transmission in the PARK position, the current flows to the BTSI fuse located in the underhood bussed electrical center (UBEC) through CKT 275 (LT GRN). The current then flows to the TCC/stoplamp switch through CKT 584 (LT GRN/BLK). The current continues to the BTSI solenoid through CKT 1135 (DK GRN/WHT). The ground path is provided through CKT 1850 (BLK) to G207. When the brake pedal is depressed, the normally closed contacts in the TCC/stoplamp switch open and the current flow is interrupted. When the current flow is interrupted, the BTSI solenoid de-energizes. The transmission may then shift to another gear. When the transmission shifts to another gear (except PARK), the contacts in the park/neutral position switch open. This condition stops the current flow to energize the solenoid when the brake pedal releases.
Whic
CAUTION
Since you must work under the vehicle to adjust most shift linkages make sure you properly raise and support the vehicle before working under it. Also, wear safety glasses or goggles while working under the vehicle.
A voltmeter can be used to check the switch for voltage when the ignition key is turned to the START position with the shift lever in PARK or NEUTRAL. If there is no voltage, the switch should be adjusted or replaced.
The brake switch was found to be faulty. Thanks for your help. the solution was spot on.
I started my car an it got stuck in starting making starter stoll position an made noises when gears chang
