SOURCE: i've just bought an acer
Hi i had the same problem with an acer gemstone, but i discovered suyin drivers are not the appropriate drivers. In Acer empowering technology is an option for reinstall only divers, and in the list appeares a driver named "Bison AcerCrystalEye". I reinstaled it and my cam back to life.
Hope it help.
Ana
SOURCE: I don't have a webcam on my ACER Aspire M3910-2.
You would have to buy a web cam, most install just by plugging them into a usb port and letting windows find a driver automatically. Running the install cd that should come with it will give you better performance than using a generic driver though.
SOURCE: Need Lan driver for Acer Aspire T650, Motherboard ERC410M.
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters could see a yellow question / exclamation mark? ! or a red X right click install drivers
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
http://download.cnet.com/lan-driver-nvidia-ver/3000-2112_4-162233.html
http://download.cnet.com/atheros-ar8121-ar8113-pci/3000-2112_4-191674.html
hope this helps
