No, but you will have to replace that entire glass shelf, as it is not sold in pieces. there is a rubber seal on the back of it that slides out. That may not come with it and you may have to transfer it over. Good Luck!
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was: 1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer. 2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open. 3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
