Have you unplugged it? Or is there a hard reset for it other than the reset button? Can you try to hold the power button down and see if that does anything? But try to pull the filter and stuff out again, after you have unplugged it, see if that works.
the manual tells that on all routers. for sure this.
RTM ?
asus.com
read the manual on how to use the HW reset button.
used only if can not log in to router and owned by you ,not ISP
1.printer is offline 2.push resume button is red and in the same time push power button 3.do no let resume (red) button,and push the resume button 2 times 4.wait to appears numer zero to the screen 5.them push four times to resume button 6.close the printer and start up
On the right side of the steering wheel there is a button that says "setup". Turn the ignition key to the on position, push the setup button and hold it until the change oil warning shows 100%. There should be a message that pops up telling you to push the reset button to the right of the setup button. Push the reset button and hold until the message confirms the oil life has been changed to 100%. Release button turn off ignition key. Now start the engine to make sure the warning light does not come back on. If it does, try again.
Here are some things the book doesn't tell you: You have to completely reset the speedometer and lose your odometer to reset the MPH. Hold both buttons for 3 secs to get reset. (Remember to use the left button to walk through the setup process and use the right button to change the settings.) First set the wheel size using Ideluna's settings above on this page (right button to change the setting and left button to go to next number). Next is MPH/KPH, after wheel size setting, push left button again and km flashes. Push right button to change the setting to MI. Next is TIME. Push left button and you'll see the time. Hold down left button till 24hr appears. Push right button to change to 12hr. Then push left button to go to flashing hour. Change with right button. Then left button to go to flashing minute. Right button to change minute, hold down to change minutes fast. Now you are set up. Now the process changes, use the right button to walk through the menu and use the left button to reset. Don't push both buttons anymore unless you want to reset everything again. If you want to reset something just hold the left button down until 0. When you are in SCAN mode, push the right button to go to Time, To go back to SCAN once, hold the right button down - It will scan everything once and return to TIME. To go to ODO, push right button once, push again for DST, push again for MXS, push again for AVS, push again for TM, push again for SCAN to stay in SCAN.
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
TURN IGNITION KEY TO ON POSITION THEN BACK TO OFF 3 TIMES 3RD TIME
LEAVE IT IN ON POSITON THEN DEPRESS GAS PETAL TO FLOOR 3 TIMES. TURN
KEY OFF SHOULD BE RESET
On my 2005 impala you turn the ignition on and turn the radio
off. Push down the tune nob until settings is displayed on the radio.
Push the seek button until you see oil life. Push the next button on
the radio until you see the word reset then push the tune nob again.
this will reset the oil timer on the car and change oil light should
turn off.
