Roxio Easy Media Creator 7 Logo
Posted on Jan 24, 2009
Have Roxio 7 and want to install it on Windows Vista
How do I fix Roxio 7 to load on Vista
how do I retrieve music saved w/ Roxio 7 on Vista
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jun 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
14479
Points
29
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
ana cruz
Level 1:
Habit-Forming:
New Friend:
  • Contributor 12 Answers
  • Posted on Nov 29, 2018
ana cruz
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
12
Questions
0
Helped
1143
Points
58
Our windows technical support team primary aim is resolving every window related issue, if have any kind of technical issues as windows installation, reinstallation, setup, keys related issue, or configuration issues all these types of issues user call us any time our technical support team at toll-free windows technical support phone number 1-888-964-8356.
My laptop turns on then freezes how do i fix this?
The music you have on your computer should have no bearing on your start up problem, this is more likely to be caused by a different area of the system such as a recently installed device or program.
Have your tried starting your computer in Safe Mode - press the F8 function key during the initial boot display and before Windows starts to load.
Further recovery actions will depend on which version of Windows you have installed (XP, Vista or 7).
If you can get into System Restore then you should try restoring the system settings back to a time before this problem started if possible.
If you can't use System Restore but can start in Safe Mode, then download a copy of CCleaner and use this to perform some house-keeping clean-up to get rid of temporary files, clean up registry entries etc as this may help.
If you can't start in Safe Mode then you will need to have access to your Windows installation media (CD or DVD depending on which version of Windows). For Vista and 7 you can try performing a Startup Repair - for XP you may have to do a Repair Install.
2answers
Says my system does not meet requirements . Cannot download . Running Windows Vista with Service Pack 1
You need to install Vista Service Pack 2 Minimum System Requirements:
  • Microsoft® Windows 7 Home Premium (32- or 64-bit), Microsoft® Windows Vista™ Home Basic SP2, Windows® XP SP3 (32-bit) or SP2 (64-bit), 1 GHz processor and 512 MB RAM
  • 1024x768 DirectX 9.0c compatible graphics card with at least 16-bit color setting, sound card, DVD-ROM drive
  • 2 GB free hard drive space for installation
  • Windows Media Player 10 or higher
  • CD Writer for audio CD and DVD Writer for DVD
  • Internet Explorer 7 and 8
  • QuickTime player version 7.6 for some functionality
  • One available USB 2.0 port
2answers
I bought HP laptop with Windows Vista Home Premuim. After I installed temperary version Windows 7. I do not like Windows 7 and I want to return for Windows Vista ( I have all necessary its numbers)....
Hi Victor, you need a bootable vista disk.
Now insert the disk into your CD Rom and then boot it up and then follow the instructions and install VISTA operating system. If you are not a professional contact me back I will give you instructions step by step.
Regards
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Two computers ago, and two operating systems ago I purchased MGI Photosuite 4 software. I have been using it for about 10 years. I have hundreds of collages saved that require the MGI software to read and...
Wndows installers have changed over the years, so it's not a surprise that the program couldn't be reinstalled. The Roxio Photosuite 8 is listed as a Win2000-XP product; so it may not be the correct release for Win7 either unless you use a workaround. Look here for the current Roxio slide show products: http://www.roxio.com/enu/store/photo.html?rTrack=m_pro_photo
Workarounds: go with a dual-boot or virtual computer system. Win7 Pro and Ultimate let you run a virtual XP computer for free (download two programs - the virtual PC software and then XP mode). All other choices will require a licensed version of XP installed either in the virtual computer program or in a second partition for dual-boot. I've found that files can not be transferred directly from XP mode to the real computer; they must be stored on external media. Then install your software as you would on any stand-alone computer.
I hope this helps.
2answers
Hi Name is Joe.
Resolution
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
7helpful
Is Roxio 9 compatibility with windows 7?
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
2helpful
2answers
When installing Roxio Easy CD & DVD Burning in Vista message pops up saying the software is incompatible.
Yes, Roxio Easy CD is not compatible with Windows Vista. You either need to remove windows Vista and install Windows XP, or purchase the newest, latest copy of Roxio.
Installation and operating failures to save or burn.
When you install the program, it provides an Ignore button to avoid the conflict? It's strange that you must uninstall one software to use the other one.
1helpful
Will not load on windows vista not compatable
Previous versions of Roxio or Sonic branded software that are not listed below as Vista compatible may run into compatibility issues. The following Roxio applications that work with Windows Vista are:
WinOnCD 9 and above
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
RecordNow 9 and above
MyDVD 9 and above
You will have to upgrade the software to an vista compatible version:
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000004GN&PARAMS=
Top Roxio Computers & Internet Experts
 Grubhead
Grubhead
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
