20 Most Recent Roxio Easy Media Creator 7 Questions & Answers
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
Roxio Easy Media... | Answered on Nov 29, 2018
Look carefully at your disk and check for any scratches or fingerprints. There are ways to clean scratches to make a CD work again, using creamy peanut butter and a soft napkin or cloth, for example (but be sure to not follow the circular 'grooves'---wipe from center to edge or vice versa, and remove all traces of peanut butter before reinserting it into your computer!)
Roxio Easy Media... | Answered on Nov 07, 2017
Depends what OS system you are on. But most windows OS have Control Panel. If you click that you will see an option to install software. Click that and wait for the Sony software to show up in the list of software. Then click it and follow the instructions.
Roxio Easy Media... | Answered on Dec 11, 2014
If u have windows 7 64bit load in cd or dvd rom this cd and install wnidows7 64 bit before installation u r format u r c drive and then install it and re install u r all software enjoey
Roxio Easy Media... | Answered on Nov 21, 2013
Go to start button, control panel, uninstall programs under the programs catergory. Find the Roxio program you want to uninstall. Click on it and click uninstall at the top of the window. That will start the uninstall wizard. Follow the prompts to uninstall. You may need to restart your computer afterwards.
Roxio Easy Media... | Answered on Feb 06, 2011
You must contact Roxiofor the solution. Here
Roxio Easy Media... | Answered on Dec 25, 2010
check roxio configuration the check if it is using the right drive.
sometimes the burner programs try to burn discs in virtual drives.
Roxio Easy Media... | Answered on Oct 27, 2010
Can you please tell any error it is specifically showing or just saying as error occurred.?
Thank You
Roxio Easy Media... | Answered on Oct 16, 2010
The following steps will completely remove any Roxio and Sonic software from your computer.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -
Roxio Easy Media... | Answered on Sep 20, 2010
If you are getting an error "No dvd/cd drive detected", you need to delete the roxio certificate.
Goto C:\program data\, find the roxio or sonic folder and delete it and restart the computer.
Regards,
Shrey
Roxio Easy Media... | Answered on Jul 15, 2010
click on start then control panel then click on audio devices and sounds check your audio taskbar to see what is selected for your audio output device. Select the amplifier associated with the tuner card. Also, right click on the speaker in the bottom right hand side of your screen in your taskbar and then select adjust audio properties. When all of the slide bars, see if your tuner volume is listed. if it is not, left click properties and see if it is listed there. if it is but not checked then check it. now go back and it just the volume for it.
Roxio Easy Media... | Answered on Apr 03, 2010
Hi!
To fix your problem, you'll have to update your graphics adapter driver.
Please specify your graphics adapter model if you need more assistance in that matter.
Alternatively, follow these steps:
1. Open the program.
2. Go to Tools -> Options -> Graphic Test
3. When it finishes, click OK.
4. Close and restart the program.
It's recommended to follow those steps even if updating the driver solved your problem.
Good luck,
Pelu.
Roxio Easy Media... | Answered on Mar 19, 2010
Please uninstall the program and reboot the computer and install the program again, that should solve most common problems.
Have a nice Christmas
Let me know
Please rate my answer
Roxio Easy Media... | Answered on Dec 12, 2009
I am not sure what your program has to do with your USB drive. what system are you running?. You may need to uninstall the USB port in device manager and restart your pc and let windows detect it.
the question mark means the picutre need to be named
Roxio Easy Media... | Answered on Nov 11, 2009
Yes it certainly should be compatible with the CD/DVD drive.
Roxio has it's own burning software included with the program, you will just have to explore the software until you work out how to burn a CD using Roxio itself.
If you want to try another burning program try Nero 9 trial. All you have to do is enter your email address and then download the software. Nero is an excellent bit of software, i personally have never had any problems with it.
Get Nero 9 here >>>>>>>>>>
http://www.nero.com/eng/downloads-nero9-trial.php
Regards.
Roxio Easy Media... | Answered on Sep 29, 2009
Start -> Control Panel -> Add/Remove Programs
and remove ROXIO.
Then, access http://www.MajorGeeks.com
and download "AShampoo V6 Burning Free Edition" and install it.
Great software, and Version 9 (which is not "free") is even better.
Roxio Easy Media... | Answered on Sep 16, 2009
Roxio Easy Media Creator 7 Logo
85 questions posted
Top Roxio Computers & Internet Experts
Peter Dragonetti
Thomas F. Schneider
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Roxio Computers & Internet
Most Popular Question
certificate file missing in roxio
  • Computers & Internet
