I have the plastic nut type on my kenmore and I am using the 1/2" rachet extension and all it does is spin in either direction, how am I supposed to get this out?
Unless the nut is stripped, it should just loosen in a CCW direction and the whole top portion of the agitator will lift off. Is the entire top portion of the agitator spinning when you attempt to loosen the nut? If so, have you tried holding the top portion of the agitator in place while loosening?Unless the nut is stripped, it should just loosen in a CCW direction and the whole top portion of the agitator will lift off. Is the entire top portion of the agitator spinning when you attempt to loosen the nut? If so, have you tried holding the top portion of the agitator in place while loosening?
You can't post conmments that contain an email address.
If you've already completed the replacment, congrats. I hope everything went well. Let me know if you still have questions, or need further assistance.
You get a 3/4 drive extension and rachet and unscrew that nut (righty tighty lefty loosey) and the top portion lifts right off. It is actually easier than the old style.
The agitator has two parts. One is the bottom agitator and then you have the top agitator that moves the clothes around. If the top part of the agitator is not moving. You probably need to replace the dog ears.Check theagitator dogsinside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is aninstruction sheetthat came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please seethis linkfor some repair aid. --click on this link directly to get the detailed instruction for replacing dog ear http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=136 to remove the whole agitator check out the instructions as follows: (1)Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1,picture2. (2) Kenmore washer.....Remove theagitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have asquare in the middlethat the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove theboltholding down the bottom 1/2 of the agitator, lift up on the agitator.also you can get the exact required parts from www.repairclinic.com This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. 2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up. 3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove. 4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier. 5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand. 6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple. 7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly. 8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position). 9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly. 10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. 2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up. 3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove. 4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier. 5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand. 6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple. 7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly. 8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position). 9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly. 10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
With a flat blade screwdriver or putty knife, remove the top cover from the agitator. Use pliers to pull out the inside plastic cover.Take a 7/16 socket on a extension and remove the nut .Pull the agitator out. It should separate. If it does not separate,stand on the lower half and forcefully pull up on the upper half.Remove the agitator dogs and spline gear from the upper agitator. Replace the dogs. Re-assemble the agitator. Wash clothes.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer: http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
sorry, i just figured it out when you asked if I was holding the top. Thanks
