Not all of the water drains from bottom of drawer. Leaves approx 1/2 cup at end of cycle. Also dishes are not fully dry at end of cycle.
SOURCE: Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
SOURCE: water not draining from drawer
Could be the little non return valve mounted underneath the top drawer. Lie down on the floor under the top drawer, remove the main plastic pannel covering the bottom to expose the black drainage hose (you may need to cut away a cable tie). Remove the drainage hose from bottom of the drawer - at the start of the drainage hose there will be a small rubber type flap - if it looks broken or worn out, it will need replacing - call F & P for a replacement, approx $5 + postage for a pair (one for the top drawer and one for the bottom)
Hope this helps
SOURCE: The bottom drawer is filling
Hi
This means that you have an overflow leak problem. You need to shut off circuit breaker or pull fuse. Next let it dry out for up to 4 days ,peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer The lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub. Replace the chopper unit.
http://en.wikibooks.org/wiki/How_To_Repair_Dishwashers/KitchenAid_Repair/Chopper_Replacement
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
SOURCE: Does not clean the dishes. leaves residue of
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Residue and Film on Dishes
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
SOURCE: bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
