Looking for the stand as do not want to wall mount
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
SOURCE: Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
SOURCE: Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
SOURCE: removal of flat screen pedestal so I can wall mount tv
There a 4 set screws on the back of the TV. There is actually an arrow pointing down to show you what direction the pedestal. Remove thesze screws and the pedestal comes right off.
SOURCE: need a replacement stand for Emerson TV model EWL20S5B
did you ever sell your stand for that 20 inch flat screen TV? if not I would like to make an offer
