SOURCE: pfaff 7550
Press the small white number 1 button while turning on the machine. You language selections should appear.
SOURCE: Pfaff 7550 synchronizer
Hi Britt,
Pfaff repair parts are only available to authorized Pfaff service technicians. You can locate your local dealer using Pfaff's Dealer Locator.
Hope you are able to get ***********'s machine up and running soon - not fun to be without!
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
SOURCE: Does the Pfaff 7550 run on electrics here and other places?
Somewhere on the machine, usually the bottom, there is a switch to change the voltage settings of the machine. Please check that and your users manual for clarification.
SOURCE: My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
SOURCE: I have a pfaff 7550 that needs a new or repaired
Do you want to learn how to repair sewing machine by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
