LUBE the deck belt+ roller bearing too. see the video and proceed according. If the problem persist after you lube , time to change the deck belt board complete. God bless you
Same as the Ford Ranger. The Airbag Interlock for turning the Passenger side air bag off has a burned out light. You can dismantle this unit and replace the light with one from ford but it has to be soldered in place.
4 years later... I'm pretty sure it has to do with liquid in the slow cooker (maybe relating to temperature also so it doesn't overheat/burn your meal?). I just threw in some short ribs and a thick (and somewhat scant for the cooker's capacity) bbq sauce. It started beeping and beeping and beeping at fairly frequent intervals. I added about a cup of hot water and the beeping stopped.
1)lube the DECK BELT, you have a lack of maintenance schedule. mAYbe you have a deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for to protect the electronic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board,for input voltage motor, if there are NOT the board is faulty.
5) Try to run the software calibration for diagnose, troubleshooting,etc
Continuous long beeps-RAM error 2 short beeps- BIOS error 1 long and 8 short beeps- Display Card error 1 long beep after few seconds 2 short beeps-FDC error 1 long beep after few seconds 1 short beeps-FDC is Ok 1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
