Water valve is working,But no voltage comes from electronic module.
SOURCE: miele dishwasher g664 12 years old maybe?
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
SOURCE: I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday:
8:00 am - 8:00 pm EST
Saturday-Sunday:
Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
SOURCE: I have a Miele G898
Hi As the drain pump is clean & fine so check the water
inlet line and the water inlet valve. To do this unplug the dishwasher then
turn off the water and then unscrew the waterline to check the inlet screen for
water inlet valve. After this if the issue returns and the water inlet valve is
getting power then it means the water inlet valve is bad & should be
replaced. Hope this helps...please post back for further assistance. Daniel
