I have an Optima G2430 Miele dishwasher that has been in use for only 3 years. Using the Normal cyle the intake/drain light started flashing in the beginning. I saw a F13 error. No water appeared to be flowing into the unit. We checked everything according to the manual...water supply is on, water inlet filter is clean, triple filter is clean, non-return valve is good, and checked the spray arms. What else can we do before calling service?
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Hi
Intake/Drain light flashing means an issue while draining. The
dishwasher is not draining properly. Please check for air gap on the dishwasher
is not clogged. It prevents dishwasher from draining properly and sometimes the
drain flow is restricted due to gunk. Cleaning or bypassing the air gap will
resolve the issue. If this doesn't resolve the issue then it is due to seized
(or stuck) drain pump. Keep handy large bowls and towels to soak the water out.
Disconnect the power to the dishwasher or turn off the breaker to the
dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections and
switch it on. If the error still appears then turn the rotary selector switch
to "Stop/End" or press the "Start/Stop" switch for approx.
5 secs to cancel the error message. Switch the appliance off and then back on
again. Hope this helps...please post back for further assistance.
Daniel
