Hi, I have a Miele CVA 2650 that suddenly died on me. There's power on the outlet but no signs of any life in the display. As far as I can see no replaceable fuses on/inside the machine. Approx 4 years old. Any idea what it could be?
SOURCE: can you give me the process to descale the miele cva 615 coffee machine?
Here you go just click on this link I put the manual on my site: http://yalda.us/CVA615_us[1].pdf
SOURCE: display message - brewunit block - can not undo to
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
SOURCE: HI THERE! I HAVE A MIELE model CVA 615 and no more
You can remove the end tip of the steam pipe and clean it dry milk can block hose. If you litlle steam pressure you can boil water in a glass and keep it allnight long so the dry dirt milk can be soften and the pressure of the same steam can spit all the dirt out so the steam hose can be clean again.
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
