Go here > http://www.gshock.com/support/ to download the manual.
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
SOURCE: watch alarm
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: Do not know how to
I had the same nagging problem on my GSHOCK 2816. The Casio manual was no help at all. What I did to turn my alarm(s) (mine has 5 independant alarms) off is switch to alarm mode (as you are looking at the face of the watch, it's the bottom left button. I push it twice to get to alarm mode. My display shows the current alarm time, and then the number 1. If you hit the top right button on the watch, it turns this alarm off. If you hit the bottom right button, it cycles to the next alarm in the list. To set an alarm, just cycle to the one you want, and then hold the top-left button until you see it flashing, then use the right side buttons to adjust the time. Hope that helps. This was a big pain in the **** until I figured it out.
SOURCE: how to change from 24 hour to 12 hour on g shock
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
