2003 Nissan Sentra Logo
Edwin bivins Posted on Jan 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil on spark plugs - 2003 Nissan Sentra
Anonymous
Level 3:
Genius:
  • Master 1,669 Answers
  • Posted on Jan 01, 2013
Anonymous
Master
Level 3:
Genius:
Answers
1669
Questions
Helped
428265
Points
5349
If the oil is on the tips of the spark plugs, you have a blown head or head gasket. If the oil is on the outside of the plugs the valve cover gasket on that side ids leaking oil...replace the gasket!
1helpful
Craftsman 6hp.lawnmower oil pouring out of spark plug hole
Either someone put to much oil in it or a piston seal has failed. Try removing some of the oil and cleaning out the spark plug port and spark plug (maybe replace the spark plug with a new one. If it is a blown piston seal take it in for service.
CHANGING SPARK PLUGS ON A 2002 LINCOLN LS
Generally in a spark plug is 60000 kilometers, if fuel is bad need in early, remove the spark plug, such as for auburn or rust color, spark plug showed normal; Such as stained with oil, shows that the spark plug gap imbalance or too much oil, high tension line short circuit or open circuit; Such as black smoke, spark plug type cold wrong or mixture is thick, the oil is up; Such as the top between the electrode and sediment, when for the oily sediment, shows that the cylinder into the oil has nothing to do with the spark plug, when the black sediment, spark plug carbon deposition and bypass, when grey sediments, is a gasoline additive covered electrode lead to lack of fire; If serious erosion, such as the scar at the top, with black pattern, electrode melt, showed that the spark plug is damaged.
hope help you -auto diagnostic tool
Oil on Spark Plugs
If the oil is on the outside of the spark plugs, you could have leaking valve cover seals or gaskets.
1990 honda accord dx/ oil on spark plugs
i put gasket maker around the spark plug gaskets cause honda are notorious for oil leaks on the spark plugs
2answers
Oil got to spark plug because a hose got burned and broke 2002 passat
Change all your Spark Plugs and check the condition of your coil wires or packs and clean them if they are soaked with oil.
4helpful
2answers
Changed the spark plugs and the old ones were covered in oil
i'm guessing that your car is a 4-cylinder. this is common for inline 4-cylinder engines. since the spark plug holes usually go through the valve cover, the valve cover gasket will leak and collect in the spark plug holes. to fix this you will have to replace the valve cover gasket.
2answers
How do i change spark plugs
get your tools out and learn on the job
1helpful
3answers
My 1994 Honda Accord has been leaking about a quart of oil every two weeks. I had the oil pan replaced and it is still leaking. Last week, I replaced the spark plugs and three of the wire holes on top of...
your need a valve cover gasket set. It comes with 4 rubber seals for the spark plug tower so oil does not leak on the plugs. Common problem, Simple to fix. Takes about an hour
2helpful
Oil in 1 1997 chrysler lhs spark plug tube
although I am not familiar with this particular engine my son's Mazda Miata had oil in the plug holes and it only required a new valve cover gasket to fix it.
16helpful
4answers
Oil around spark plugs on 1992 honda accord
Yes the oil can cause the car to lose spark, the oil leak could be caused by the valve cover gaskets around the spark openings, but 9 times out of 10 it is the spark plug tube "O" rings. The top of the valve train comes off of the head, the "O" rings are between the two halves, that will fix the oil leak.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
