Ok more detail. We moved the stove over seas to Thailand for our house. It is a 110 uint. I have a 1500 watt transformer to covert the 220 to 110. The transformer is putting out 105v ac. When I plug the stove in, the display will light up for a second or two, then turn off. It will do this again and again. I have check the main board for fuses and mad sure there are no loss wires. Thank You Bruce
SOURCE: bosch exxcel
The likely cause of this is a failed heater element which would cause the fuse to blow. You will need to get the heater element checked out and replaced if necessary. A visual inspection of the element may reveal the problem jf not an electrical test will be necessary. Be sure to switch off the power before touching the heater element.
ok some more news. New transformer puts out 110vac, and the sparkers work on the burners. The board still goes on and off. Bruce
