Question about Honda 6370C - Parallel Power Kit For EU3000i
Honda EU30001 generator causes erratic pellet stove operation.
I have a Honda EU3000i generator for powering my Harman Invincible Pellet stove during power outages. The stove runs poorly on the power from the Honda-- the fan that blows the hot air into the room only operates intermitently whereas on house current it blows non-stop. Also the fire burns poorly as the combustion fan motor also operates weakly.
My refrigerator and electronics all work perfectly on the Honda power. The pellet stove performs poorly whether the other items are hooked up to the generator or I just run the stove alone.
Why can't this high-end Honda generator run my stove correctly? That's why I bought it!
Posted by sandpipe on
electronic & computer repair& servicre
  • 12,061 Answers
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Posted on Feb 26, 2010
I cleaned my Harman Pellet stove today and when I went to start it the feed motor won't start. The blower runs for about 15 sec then shuts down
Test the feed motor with a jumper and wire power to it directly, if that fails to make it run you have a defective motor.
Dec 27, 2016 | Pool & Spa
Harman pellet stove blower not coming on. All lights are on and not blinking.
well im not sure why a pellet stove question is here in the pool section , but I do own a pellet stove (and a few pools too) SO I can offer one thing to look for , there is a small switch on the side of your burn chamber (soup can looking thing) this switch is what controls your fan to come on . it works by sensing heat from burn chamber and then turning power on to fan , its possible this isn't passing any power on yours ?
Oct 04, 2016 | Home
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Can I run a pellet stove off a generator its a 3500 Watt generator I bought at tractor farm supply Just need to know Yes or no I got a harman invincible insert pellet stove
If you are just running the blowers and what not, then yes you can. Blower motors do not take more than between 200 and 500 watts or so, so you should be okay running the blowers.
Jan 06, 2014 | Electrical Supplies
Honda eu 2000 generator surging
remove the throttle control motor spin motor a few times. I believe due to the minimal rotation required during activation a flat spot or build up results in a poor connection. Kicks down under load now. Back to the smoothnes of a new unit
Dec 28, 2012 | Honda 6370C - Parallel Power Kit For ...
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Wont run off 1/2 choke
I had a problem with a honda generator that would only run on full choke. I removed the carburetor and cleaned the main jet with a wire and carb spray. Problem solved. Fuel stabilizer should be used with todays gas mixtures that have ethanol in them. Hope this helps.
Aug 29, 2010 | Honda 6370C - Parallel Power Kit For ...
Honda EU3000i is rated to put out 15A but won't
If you attempt to use a 15 amp generator to power a 15 amp appliance you will have a big problem. Always plan to use no more than 80% of any power supply. You are currently trying to use the absolute maximum power this generator can supply, and it's probabally not rated for that load at continious use. Get a larger generator, or , a very sharp axe.
I hope this information was useful for you.
Joe
Mar 06, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda 6370C - Parallel Power Kit For  EU3000i Logo
977 people viewed this question
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
