20 Most Recent
Bosch HGS3052U Gas Kitchen Range Questions & Answers
Bosch Stove will not work
Is your power 50 cycles? If it is the electronics in the stove need 60 cycles. You might want to contact a local bosch dealer there to see if there is a board meant to work on 50 cycles.
Panel doesnot work
it sounds like the display kit
AP4929088 is bad and will need to be replaced. It will cause the problems you are having with the unit. Hope this helps. If you have purchased in last year, it may still be under warranty
Panel display doesnot work
AP4929088 is bad and will need to be replaced. It will cause the problems you are having with the unit. Hope this helps. Is your Range still under warranty? it has some rules listed in the manual it maybe good for parts replacement for 365 days from purchase.
I just converted from NG
the oven orifice hasn't been tightened all the way down. sometimes it feels like it is down and tight so you need to look at the orifice and see if it's all the way down. if not tighten it some more.
Bosch oven model HGS3052UC doesnt close tightly,
yesthis is a common problem with this brand. 2 things can be done. 1. replace the hinges left and right or add 3 washers on both sides of the hinge to bring the door hinges closer.Im a old bosch tech and I told them this was a issue.
OVER WONT HEAT UP
make sure the hose is connected to the propane tank and that the tank valve is opened letting gas into the grill exhausts... and then light the igniter but make sure the release valves on the grill arent on max... start it on low to med.
Bosch HGI8054UC warming drawer won't close completely
The slides require replacing.The functions part on the rear of either the right or left side has failed causing your drawer not to close. It cannot lock so the spring pushes it out. The part on the rear that locks it in, and ejects it out some how gets damaged. Need a T 20 star/torque bit to replace. The part number for the slides is 12024638. You can pull out the drawer but be careful of the rail that will stick out. Don't let the drawer land on your feet. If you don't order the parts yourself and install this, you may call the Bosch service to do such for you --though you have noted the expense.
What are the dimensions of a Bosch WFF 2001 washing machine please
Most domestic washing machines are built to a standard size regardless of manufacturer. So if a standard machine was removed this machine should fit. The standard height is 85cm and the width is 60cm. The depth can vary depending on the drum size. A bigger capacity machine will stick out further from under the counter top.
Bosch gas range no lower ignitor for bake no upper ignitor for broil display is fine no type of error code no other issue any recommendations?
It sounds like there is an issue with the ignition system of your Bosch gas range. The fact that the display is fine, and no error codes are being displayed, suggests that the problem is with the ignition system itself.
- The first thing to check is the ignition switch, it could be faulty and not sending power to the ignition system.
- Check the wiring, it could be loose or corroded preventing power to reach the ignition system.
- The next thing to check would be the spark module, which controls the spark that lights the gas. If the spark module is malfunctioning, it will not send a spark to the ignition system.
- Lastly, the oven and broiler igniters may be faulty and need to be replaced.
It's important to note that working with gas appliances can be dangerous, if you're not comfortable troubleshooting, it's best to contact a professional for repairs or contact Bosch customer service for further assistance. Request for a senior technician or supervisor to take a look at it and provide a resolution.
Regenerate response
I have a bosch exact
Well i now have the answer to the bosch stove dilemmas if you have a glass touch panel on your bosch stove and you can't get the touch buttons to work right then check the circut board on the back of the glass it is cheaply held to the glass with a non hardening caulk and when your oven heats up the glass panel
the caulk gets so soft that the circut board and the caulk seperate causing inconsistent button operation. To solve this push the circut board and its frame back to the glass then get some aluminium tape at the building supply you shop at in the heating section and tape it into place so it can't seperate anymore then it should work for you. Make sure you have everything grounded properly.If you are concerned about the grounding you can use duct tape to be safe. ( there has been a lot of complaints about glass touch panel incosistentcies on more than one model so im 90% sure this will fix those too).
