Water condensates along side of refrigerator accumulating on shelves & freezing at input into refrigerator at top, also freezing behind fresh food drawers, causing doors not to open
SOURCE: I've got an electrolux frost
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
SOURCE: Would like a digram on how to pipe up condensing unit, bar fridge
Explain what you need a little better email me and we also will communicate the results here, Thanks Sea Breeze
e-mail
[email protected]
site link
http://servicepartstec.blogspot.com/
SOURCE: freezes food in refrigerator side
the problem should be with the temerature controller in the refrigerator. ask for the nearest technicain to come and fix it.
SOURCE: We have a Frigidaire refrigerator-freezer that
Hello, Your problem is going to be with the cold control, it is not shutting down which is why the food is freezing, You did not supply a model # so am unable to see if theis has a thermostat or control board, will assume it has a thermostat. Most likely place to find it is where the know for controling the freezer is...usually inside the fridge. Replace this thermostat and you will be good to go...Thanks for using Fixya, if you have any additional questions or concerns please feel free to comment again. Good Luck!! Mike
