Every possible recovery process has been done and every time it will crash and it wont let me select the acer e-manage on alt f10 it brings up a screen asking for boot options and i have /NOEXECUTE=OPTION and every time i delete or select it will start up then crash again?
How can he type that command murbak359 when his pc crashes when it boots up? makes no sense, only way to try is load safe mode if that works and then use the command there if not try ussing a restore to a access point it made before crash starts to happen.
hello and thank you for the reply i have tried but every time it gets to loading the system restore/install windows it will crash, i have had the hard drive out and had the windows 7 disk to boot from and it works fine to the point that it then needs the hard drive to proceed? so what i need to do really it try and format my hard drive another way or buy another?
Try starting up in Safe Mode (Console mode) and type in
"SFC /Scannow"Once its done you should be able to do recovery options.
If not, boot from the windows 7 recovery/install CD and choose "Repair".
Go through the recovery process using the CD and it should all be fine!
