If you are playing games that use lots of graphics. You might not have enough computer ram installed running your computer over its limits placing to much strain on the cpu central processing unit causing memory dumps and crashes.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible. Hope this helps.
SOURCE: My Google Chrome crashes when
Uninstall google chrome and do this Repair Active-X, Flash and Other Registry Error using registry cleaner reginout check Flash Player Compatibility Updating the Sound Drivers now install google chrome , it will solve the problem
SOURCE: Shockwave Flash keeps crashing while
Try updating the Flash player on your system go to adobe.com and download flashplayer from downloads here is the Link.
I hope this helps.
