SOURCE: System Code Error 87
Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
SOURCE: system says that program not responding
From what you put on this, it seems that you have a KERNAL32 error.
Fault Module Name: kernel32.dll
the application being Windows Media Player
Application Name: wmplayer.exe
I've researched this thru microsoft and the best thing I can find
Go to Start - > Type Run in the Search Box - > type regsvr32wmp.dll
What operating system are you using? Because the KERNEL32.DLL file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (ME).
SOURCE: ERROR IN COUNTER STRIKE GAME IN WINDOWS VISTA
before you run the game right click the icon that launches it and goto properties, goto compatibility tab, check the boxes run in compatibily with xp sp2 and check the box to run as administrator, click apply ok then run the program.
SOURCE: Explorer.exe Application error in Windows XP Professional SP2
i think you must to format it with the good cd windows because the problem is has an error while installing windows. thx
SOURCE: FIREFOX executed an invalid instruction in
http://www.fix-all-dll-errors.com/npswf32.dll/
The problem is due to the npswf32.dll file. You can find solution here...just follow the link.
