Samsung LN46A530 46 in. LCD HDTV Logo
Tuan Le Posted on Dec 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 42 in Samsung (LN46A530) TV is flickering when I turned it on and it stays for a very long time.
Anonymous
Level 3:
Top Expert:
  • Samsung Master 14,553 Answers
  • Posted on Dec 14, 2012
Anonymous
Samsung Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718863
Points
48227
A lot of the Samsung's have a common issue, there is a jumper in the power supply that needs to be removed, Contact Samsung with the model number and they can tell you if your set is one, they were fixing this issue for free.
1 Related Answer
Chi Chu
  • 8457 Answers
  • Posted on Oct 27, 2010
SOURCE: samsung lcd ln46a530 is having some difficulty
The tv have 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these refurbihes 2 long LCD inverter boards for the replacement.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
2helpful
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
Half screen normal , other half blackened for 20-30 minutes, before turns normal. Recently getting longer to get normal screen and left side stays black(about 2" wide)
sounds like a bad smps or bad display. I would try the smps, but if that doesn't do it the display costs as much as the tv most likely.
Samsung LN46A530 turn tv on green hue appears
It sound the the panel is faulty. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
2answers
42inch samsung ln40b550 turn on my television it flickers wildly
This is a common Power Supply / Backlight Inverter Board issue. If you open up your TV you will see a long white board that is on the right side of your TV. You have to replace that board to get this issue fixed. You can find the board here BN44 00264B Samsung Power Supply Backlight Inverter
Is the Samsung Ln46a530 dual voltage ie (110 America - 240 Europe)
The tv power supply board is not the problems,that can add a transformer to solved it easily.The problems are US and Europe uses a difference tv signal frequencies.The US,Canada and Mexico are using a NTSC signal frequencies.Europe,Asia,Middle East and Africa are using PAL signal frequencies.U must have a tv that call REGIONS free tv to work in Europe and US same time.If u just have a standard LCD or a Plasma HD tv buy it in the US for example will not work in Europe
1helpful
What is causing my TV to display inverted colors, like a negative photograph? The picture of my LN46A530 LCD TV has degraded an it looks like if I was seeing a negative photo.
TV display inverted colors, like a negative photograph because defective panel. Mostly from T-con board. Replace T-con board.
I hope that will solve your problem.
Thanks.
Samsung lcd ln46a530 is having some difficulty turning on and when i does turn on the picture drops out( blank) but the sound stays on.
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
