Question about Samsung LN46A530 46 in. LCD HDTV
Half screen normal , other half blackened for 20-30 minutes, before turns normal. Recently getting longer to get normal screen and left side stays black(about 2" wide)
Posted by jerry laskowski on
Baker TV Repair
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Sounds like a bad smps or bad display. I would try the smps, but if that doesn't do it the display costs as much as the tv most likely.
Posted on Apr 18, 2014
5 Related Answers
HDTV GURU
Jay Henderson
  • 261 Answers
SOURCE: WHAT CAN I DO TO RESOLVE THIS MATTER--PLEASE HELP ME SOMEONE???
Are you using a cable box? If you are then it maybe setup incorrectly. If not, See if when you press the MENU button if the screen is filled. If it is ok then, then the plasma panel is good, but the video processing is possibly bad. Have you tried all video inputs? Let me know more info and i can assist more. Have a good one. Jay
Posted on Jan 31, 2008
Anonymous
  • 146 Answers
SOURCE: black line down the left side of the screen
This is a bad panel. The panel is very expensive to replace. It would be cheaper to buy a new tv. Sorry about the bad news.
Posted on Nov 17, 2008
Anonymous
  • 147 Answers
SOURCE: BOTTOM HALF OF SCREEN GOES BLACK R A MINUTE OR SO
remove the back of the tv.disconnect and reconnect the ribbon cables into your buffer pcb.if this does not correct the problem replace the buffer pcb in that location where the screen is going black.you also could have
a defective panel if the buffer pcb does not correct your problem.
Posted on Jul 17, 2009
Chi Chu
  • 8457 Answers
SOURCE: Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Posted on Dec 15, 2009
Anonymous
  • 72 Answers
SOURCE: In my samsung 40
It could be the power supply causing this problem - puffed caps in the Power Supply and low voltage to the signal board. Have both checked.
Posted on Jul 03, 2010
LG 55 UF6450 tv. The left half of the screen went to a weirdly shaded image over about 15 minutes and stayed that way.
The left side data buffer board is damaged, in most case is water leaked to the left side of the bottom screen.
Jan 12, 2018 | LG Televison & Video
Left side white. its like the whole screen has shifted to the right
The lcd convertor went out. You can get them on Ebay for a few bucks.
Dec 21, 2011 | Computers & Internet
When turning the TV on, the left half side of the screen is dark and bleared, while the other side is normal stays like this for a while, then it is gone and it appears for about half an hour.
I have had the same problem for a couple of Months . Bought my lg in March 2009, just had it diagnosed as the Screen . Apparently they are not Lg screens but a version called AUO optrix . my tv is a non economical repair and i am waiting for Currys to get back to me . let me know if i can be of any help. Mike
Nov 06, 2010 | LG 42LC2D 42 in. LCD HDTV
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
One half black verticle screen
Manufacturer Philips Part Number 932224850682 Description LCD DISPLAThis part is no longer available
Aug 20, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Picture problem
If the set is no longer under warranty, open up the back and reseat all of the connectors and cables. You are seeing a heat related connection problem. If it is still in warranty, bring it in for warranty repair. The other possibility is a heat related connection at the processing chip(s). This is a more complicated repair that should only be done by an experienced tech that works with surface mounted components.
Keep us posted.
Dan
Apr 23, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
TV Blinks on and off
Phil, from your description it sounds like your convergence IC`s are about to fail, the intermittent off/on cycle is because as they heat up there drawing too much current, the bowed collapse tells me it`s the vertical convergence IC that`s the culprit. You need to get a tech out asap to fix this or they could short and take out the power supply as well and that`s just mooore money to fix it, hope this answers your question, BMW Rider
Dec 05, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Samsung LN46A530 46 in. LCD HDTV Logo
210 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
