The dryer was off, then it made a couple of chirps and turned itself on. The dryer will not shut off and none of the buttons on the control panel work. If you push the off button it doesn't shut off. Same when you push the start button, nothing happens. None of the buttons work. The only way to shut the unit off is to manually shut off the breaker.
SOURCE: Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
SOURCE: My maytag neptune dryer won't start. The control
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
