Dryers Logo
Question about Dryers
I have model # 110.66712692. The drum will not rotate, I can turn it by hand. I have heat and the blower is working. What else could it be?
Posted by yif4 on
Ahmed Bouri
    New Friend:
Slt. Vous devez chang? le condensateur qui est defectueux c est lui qui s en charge pour lancer le moteur avec bobines de lancement puis le relayage se fait avec les bobines de travail pour faire tourner le moteur .bonne chance
Posted on Feb 05, 2018
Anonymous
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 21, 2010
How to get to dryer drum. GE mod#dbvh520ej2ww
Hello there and welcome to fixya
The most common problem with these are the motor or the motor bearings or rollers
and next is clothes getting caught between the drumb and the shell of the unit
Here is some troubleshooting help for you listed below
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor
4helpful
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
1helpful
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
1helpful
Whirlpool Electric Dryer, model LER7648KQ1. The
Check your previous post. I left additional info for you.
Sep 11, 2009 • Dryers
THE DRYER WILL HEAT BUT THE DRUM WILL NOT TURN. I HAVE CHECKED THE BELT AND IT IS OK. NOW WHAT
Hello. I can help you. Since the belt is ok there are only two other possible problems:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Jul 16, 2009 • Dryers
2helpful
2answers
DRUM WILL NOT SPIN BUT DRYER WILL HEAT IT'S A WHIRLPOOL
I have provided a checklist courtesy of; www.repairclinic.com
They also provide repair parts, disassembly diagrams and procedures.
You can also checkout www.homemanagement.services.officelive.com for other appliance help websites.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
  • Remove the belt.
Kenmore electric dryer
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
  • Remove the belt.
Aug 27, 2008 • Dryers
Maytag dryer (model LDE5910ACW)drum doesn't turn. Dryer heats up and sounds like its working but isn't. What should I look for first?
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Belt
Motor
Door switch
  • Remove the belt.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
Belt
Motor
Door switch
  • Remove the belt.
Open Questions:
0answers
Over-oiled Hunter Original ceiling fan When I tried to I oil one of my Hunter Original fans for the first time, I obviously did not understand how you measure the oil in the reservoir and, long story short, I added too much oil. I wiped as much of it out of the light fixture as I could, and when I noticed there was oil dripping from the end of the pull chains for the fan and the light, l wrapped pieces of an old rag around the end of each rubber bands to hold the fabric onto the chains. I then put the fabric wrapped chain ends in small ziploc bags and sealed them either side of the chain so they wouldn't fall off. All this was to prevent oil from continuing to drip onto my kitchen table as it had originally. They've been like that for what's probably been 6 to 8 months as I believe the over-oiling incident happened last fall. I haven't really tried to do anything about it until now when it's starting to get to the point here in the Florida Panhandle where I'd really like that fan above my kitchen table to work. But I'm afraid to turn it on because I've read that oil would get all over the flywheel if you to put too much oil in the reservoir, and it would spray out everywhere if you turned on the fan. I didn't worry about it over the winter although I do sometimes reverse them and use them when it's really cold out but we didn't even have that cold a winter so I pretty much ignored it until now. I'm pretty sure there's no more oil coming out of the fan down the pull chains because the small amounts of oil captured in the ziploc bags certainly hasn't increased and I think some of it has actually evaporated because it seems like there's less than there was earlier although it's not like I've measured it. I will, of course, start by measuring the oil in the reservoir. I wonder if it's possible some of it has evaporated. And I was wondering whether if it's still overfilled I might be able to suck out some of the oil with an eyedropper. But the question about there possibly being oil on the flywheel is still kind of freaking me out. Is there any way I can deal with this without having to take down the fan? I simply can't do that myself because it's way up high and they are too heavy for me to hold while standing way up on a I had an electrician install all my 4 Hunter Original fans for that reason. I can call an electrician to care of this if I need to, but I'm hoping I won't need to. Does anyone out there have experience with this situation and what I can do to help get my fan working before it gets even hotter out here in the Florida Panhandle? Is my idea of sucking oil out of the reservoir with an eye dropper, for example, legitimate? Is it possible oil that got on the flywheel has evaporated over time, or that the oil which slowly ran down the pull chains came from the area where the flywheel is and that perhaps there's no more to fly out of the fan if I turn it on? Does anyone know how much oil that little oil reservoir holds or how deep it is? That's all the questions I can think of for now. I hope someone who might read this has the knowledge to help me. I looked all over online and all I could find was about how to add oil - the exact opposite of what I want to do! I should note that I haven't called the Hunter Fan Company because it's not like these fans are under warranty, I don't think as I bought all four of mine on eBay. I guess I have paperwork with the model numbers and that sort of thing but I thought I'd start here because it's easier and friendlier than many customer service personnel are.
Top Dryers Experts
Marvin
Marvin
john h
