No power supply
SOURCE: acer aspire 5920- camera not found
update the driver installer or download the driver web cam
SOURCE: My Acer Aspire 5920 is not booting up. When the
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Testimonial: "Thanks for the reply! This just confirmed what I had been suspecting looking at other sources on the web. "
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
SOURCE: My acer aspire 5920 will not power on!
Hi
Thanks for using FixYa. You will need to reset the Laptop
if it is not starting up. Follow the procedure as under to reset it---
Remove all connections to and
from the laptop. Now remove the battery and press and hold the power on button
for 2 minutes. Release the power on button. Slip in the battery pack. Plug in
the power to the laptop and to the wall. Please do not plug in any other
devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
SOURCE: acer ZD1 aspire 5920G will not turn on
Problem is with the mother board. If u are an PC/electronic technician/repairer and has a similar problem wanna email me for some tips @ [email protected]
Thanks
