What buttons do you push to do a factory reset - reboot - for a Tascam DP 24 portastudio?
SOURCE: Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
SOURCE: Tascam Portastudio DP-1FX/CD
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Cheers
BD
SOURCE: Tascam Portastudio 424 Manual needed
Try this page: http://www.tascam.com/products/424mkiii;9,17,141,19.html
Regards,
BD
SOURCE: DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
