Bought less than 30 days ago. Has not been dropped. Have not used long enough to be effected by bad water. Water runs out, does not spit out.
SOURCE: iron leaks water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
SOURCE: Rowenta steam iron also spitting brown steam....it
There are chemicals in the tap water,it sounds like it has too much iron in it.Stick with the distilled water.
SOURCE: My Rowenta Expert steam generation iron (seperate
Brown water and whitescale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
SOURCE: I BOUGHT THIS WONDERFUL IRON
Try filling with water, shake gently, pour the water out and repeat several times.
Clean an iron:
Service the steam and spray mechanism:
