Says enter network lock control key?
SOURCE: How do you get rid off 'emergency calls only'?
turn the phone off and then back on. That usually solves it. Or take out the sim card,wipe it off, put it back in, and turn the phone back on.
SOURCE: My samsung Duos gt-b5722 not
Try other sim cards in the phone to be sure the problem is not from the sim. When you are sure the problem is not from the sim, try to reset the phones's factory settings. If it still does not work, then flash the phone.
If the fault was detected to be a sim fault, then get another line of the same network, and call your mobile service operators.
Hope this was helpful?
SOURCE: I forgot the Samsung Impression
SECURITY CODE:
If
you are talking about the security lock code to enter into the phone
then once it is lost nothing can be done except flashing the mobile .
Because if anybody can give the security code created then who ever who
steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if
you forget the security lock you have to reset the mobile memory by
flashing the mobile at an authorized service center.So while flashing
the mobile all the data in the mobile memory will be lost and you can
again start using the mobile.
SOURCE: Emergency calls only? Is phone locked? Is there
The is a problem with you cell phone service.
Call you cell phone provider or take their store.
If this helps please vote for my solution.
SOURCE: phone freeze pls call customer cervice provider
Contact the Service Centre of Your Phone company and get the firmware re-installed. That is the only answer for lost passwords/codes.
