SOURCE: Stuck in 3rd gear vw golf 1
dis canekt the batrey 4 10mins and than leter it till it gows up a ger and chek the oil in it
SOURCE: buzzing problem from my citi golf chico dashboard
the buzzing is most likely the speedo cable ive had a few older cars that do this you might try having someone oil the cable if they can or you can as for the oil light it might be low oil pressure or a bad oil level sensor or even a dirty plug on the sensor
SOURCE: mk1 vw golf problem starting when cold ?
The first thing you may want to do is to replace your coolant temperature sensor. This is arguably the most important sensor on the vehicle, since it tells the vehicle's computer how hot or cold the engine is. What's most likely happening, is the sensor is sending an incorrect reading of temperature, making the computer think it's warmer than it really is, causing the car to attempt to start too lean.
The sensor is generally under $20 and is easy to purchase and install. It's usually located near the thermostat housing with 2 wires going to it.
I hope this helps and let me know if you need any further assistance! :)
SOURCE: mk1 vw golf cabrio: hot starting problem?
Same problem on 1998 golf Chico replaced starter miter replaced ignition switch any ideas how to sort this out
