-> Connect your router using standard Ethernet cable
->open your web browser and login using username and password.
->Locate the page that allows you to change the IP address of the router. The address should be changed so that it is not the same as the main router on the network, or any other network devices.
->Disable the router's DHCP server. This setting should be on the same page as the IP address, but each router is a little different.
When the router is operating normally, this server assigns an IP address to every device that is connected to it. Because this router will be used as a repeater only, the IP addresses will now be handled by the main router on the network.
->Turn off the DNS server, if it is activated. This function will be taken over by the main router, or by the ISP that provides the Internet connection to your location.
->Disable any firewall that is built into the router. Usually, this can be done in the "Security" section, and it may require you to alter several settings, depending on the make and model of the router.
->Remove any entries that are located in the "Port Forwarding" section. On some routers, this may be referred to as "Applications and Gaming," and it allows certain programs to have less-restricted access to the Internet.
->Set the operating mode switch to "Gateway" or "Switch" if such a setting is available. In addition, if the router is a wireless router and has the appropriate settings, disable the wireless access or set it to function as an access point only.
->Save the settings as necessary on each page, and reboot the router. After the router boots back up, the changes should allow it to act more or less as a simple repeater.
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
Checklist:
Hardware Checklist:
PROCEDURES:
1. Hooking up hardware connections:
NOTE:
As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
3. Connecting your Repeater to your existing network access point or router:
NOTE:
If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
NOTE:
When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
5. To check the Repeaters user interface
At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
