yes. there looks to be about 12 slots. I changed out all the 15amps and the #8 slot which was a 30ampyes. there looks to be about 12 slots. I changed out all the 15amps and the #8 slot which was a 30amp
AnonymousMar 15, 2014
Need a diagram of the turn signal fuse&what side is the fuse box onNeed a diagram of the turn signal fuse&what side is the fuse box on
You can't post conmments that contain an email address.
When I use my turn signal in my 1986 toyota pickup every 5-6 uses it blows the fuse and my blinkers, backup lights, gas gauge and temp gauge stop working. What is going on
Using a test lamp, check to see if power is getting to the relay when you turn on the headlight switch. If not, the switch probably needs to be replaced.
when you were installing the cigarette lighter you may have loosened a connector to these other functions so i'd retrace where i was working and try pushing together any wirng connectors you can see/reach,if still not working i'd change the indicator flasher relay ,let me know how you get on
Try changing out your turn signal flasher.it might be under your dash by your fuse box.Some trucks have two one for turn signals one for 4 way flashers.By all means check the fuse first.
yes, you must remove the top panel on the fuse block the 80 amp fuse is bolted to the the fuse panel, hope this helps if not get back to me as i strive to be the best please rate my fix Thanks Ray
The diagram will do you no good it you do not have amber turn signals on your trailer. What you need is a "black box" that, when wired correctly, interprets the amber turn signal on the truck into a pulsed flash to the red brake lamp on the trailer. If the trailer does not have amber turn signals, it is impossible to wire a harness with a diagram. Sorry.
fuse #8 is 30amp. I replaced it with another 30amp but that didn't work.
the fuse box in the cab on the driver side
