Restart the PC. The BOOTMGR error could be a fluke.
Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
Try replacing the PATA or SATA cable if you suspect it might be faulty.
Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1.
Insert the installation disc.
2.
Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4.
Choose your language settings, and then click Next.
5.
Click Repair your computer.
6.
Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Have you installed the Windows OS on the new HDD? Insert the new Windows OS in the DVD rom drive, shut down, Unplug, remove battery, plug in, at boot the new OS DVD should start and ask Press any key to boot from CD/DVD, tap key.
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
When it's booting, try to access the setup, aka BIOS. See if you can set CD/DVD as a booting option. As the top BOOT device. Then see if you can boot your installation CD. You may be able to format your drive during the installation - if the hard drive hasn't failed?
Hi, This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
This is related to the boot sector file.So it wont work in the safemode also.Try and see that the hdd is detected in the system.If yes,then try booting thru th XP disc and run a repair
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
