The scales will not adjust to zero with the knurled adjuster. I cannot see any screw holes to take it apart.
SOURCE: Need to know how to adjust the weight
Try putting brand new batteries in and letting the scale zero out and then shut off on its own. Sometimes it's "zero" is misrepresented by an old set of batteries. Also, do any kids live in the house that might have jumped on it? If so, it would be wise to buy a new one as the sensitivity will be ruined for life.
SOURCE: Hanson weigh scales I have no manual HXM150
just go to the website and down load the manual pdf form. it should be there!
Have fun!
Testimonial: "My first time to ask for help and it was totally correct. Thanks."
SOURCE: i have a set of hanson kitchen scales and i cannot
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
