WMFC5301UC
SOURCE: noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
