SOURCE: sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
SOURCE: Images on LCD are upside down.
You have to go to settings and adjust from there...find LCD settings and that should do it.
SOURCE: i have a sony dcr-sr82 camcorder and the lcd upside down
It might be the flex wire connecting LCD with camcorder responsable. What happens when you turn the LCD on the other side?
SOURCE: when the lcd touch screen is facing me, the video
It is the switch that detects LCD position, sometimes it's mechanical switch some uses reed switch. I smell failure in this area (could be the switch or the flexi that connects switch info to CPU). Hope it helps
