Okay, I suppose you already knew about that program :-) Didn't notice the name until I clicked the "Post" button.Okay, I suppose you already knew about that program :-) Didn't notice the name until I clicked the "Post" button.
You can't post conmments that contain an email address.
Do you know that a replacement ECM would need programming ? Dealer .An it's a PCM - powertrain control module ,because transmission an engine modules are inside the same box (module) .Service of the PCM should normally consist of either replacement of the PCM or EEPROM programming. If the diagnostic procedures call for PCM replacement, inspect the PCM first to see if the PCM is the correct part. If the PCM is faulty, remove the PCM and install the new service PCM.
The new service PCM will not be programmed. You must program the new PCM. DTC P0602 indicates the EEPROM is not programmed or has malfunctioned.
There are no user serviceable parts in this PCM. The PCM should never be opened for any reason.
Important: When replacing the production PCM with a service PCM (controller), it is important to transfer the broadcast code and production PCM number to the service PCM label. Do not record this information on the PCM cover. Transfer allows positive identification of PCM parts throughout the service life of the vehicle.
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
Remove the left sheet metal diagonal brace. Refer to Front End Sheet Metal Diagonal Brace Replacement - Left Side in Body Front End.
Remove the air cleaner assembly cover and lift the PCM from the assembly.
Disconnect the harness connectors from the PCM.
Remove the PCM from the engine compartment.
if where the "U" hook is mounted is just sheet metal the that area will have to be strengthened. Get a piece of flat bar about 3/16 " thick and remove the hook, place the flat bar behind the sheet metal. Make it long enough to be able to drill outside the width of the hook. Mark holes for the hook and drill. place the flat bar behind the rear and do the hook back up
This will place the flat bar behind the sheet metal in place
now drill smaller holes for pop rivets and fix the bar to the sheet metal
This mod will spread the load over a greater area of the hook and reduce the sheet metal bending
Check the body ground cable connection. I don't know exactly where it is on your model, but it's usually a wire from the battery ground cable harness with a ring connector on the end, bolted with a sheet metal screw to the radiator mounting panel at the front of the engine compartment. (Sometimes it is attached to a fender well at the side of the engine compartment near a fuse or relay box.) If it is necessary to remove rust from the sheet metal under the connection, coat the screw, terminal and surrounding sheet metal with sensor-safe silicone rubber after assembly. Also, cover the end of the screw on the other side of the sheet metal.
No. A table saw IS NOT safe for sheet metal cutting. I have seen bar stock aluminum and copper cut on a table saw (at least 1/4 inch thick) but trying to cut thin sheet metal would be a bad idea. The two main problems are that the sheet metal is too flexible and the teeth are much larger than the material is thick.
There is only one program for sheet metal pattern development written for the ti92plus/voyage200. It was written by my friend Keith Shaw and myself, and we sell the program (recently updated to solve a couple of bugs and add new programs), cost is £35 per calculator on a cd or £30 via email. See my tutorial demos on youtube for how to load and operate the programs. http://www.youtube.com/user/RobboLagger
Hello, Yes you can transfer everything on you YI92/TI92PLus to your computer. To connect it you need TIConnect software, and a USB TI Silvercable. Once the software is installed, you can communicate with your calculator (capture anything on your TI screen as an image to your computer, install applications, transfer programs and so on).
Run TI connect on your calculator. Draw the graph on your TI 92. Connect the calculator to the computer. Click Screen Capture in the TI Connect software window, It will be store it in your user directory (My Documents ->My TI data)
