RCA 25201RE1 Corded Phone Logo
MY PHONE KEEPS INITIALIZING AND CUTS CALLS OFF
EVERY FEW MINUTES MY PHONE KEEPS SAYS INITIALIZING. ALSO, WHEN I TAKE A PHONE CALL THE PHONE GOES DEAD.
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
My ps 9010 dolmar goes dead after about 10 minutes of running
Tim:
The problem with your saw could be a few things. First, check the filter at the end of the fuel line in the tank. Sometimes the filter hangs up in a part of the tank where it is not totally submerged in the fuel. This can happen especially if you are doing side-cuts or tilting the saw. you may possibly need to adjust the fuel/air adjustment screws on the carburetor.
When I try to make a call it keeps telling me "emergency calls only" and it will says service unavailable...how can I fix this? it cuts in and out and can only make calls and place texts...
This means that the SIM card is not accepted on this phone. You need to verify and check if the phone is actually unlocked for use to other networks.
You can also try to put the phone back into factory defaults.
Let me know how that goes.
6600 slide cuts out
format ur phone by this way " *+send key+3+ power key combinely after switch ur phone"
Jul 21, 2009 • Nokia 6600
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
Lg Ks 360
you need to update your software which needs doing every few weeks
1helpful
the problem on it is the crystal IC on the display,, replace it
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
