On my Onkyo AV Reciever TX-NR903 appeared following problem
After listening to music or watching a movie after approx, 30sec. the sound goes off, it doesent matter if loud or not. the amp gets too hot (as for me) the impedance is set correctly and there is no shortcut in the speakers or the wiring.
The speakers are new and worked perfectly with my old Amp.
Try to check if the blower is working, If not then first look for the blower sensor and clean it and resolder parts pin joints and associated parts also.If ever the blower is working fine then the problem is in amplifier section caused by change value resistor or leak capacitor or cold ,loose or crack solder joint parts this the common problem of over heating amplifier caused by abnormal distribution of current,try all of this,so your receivers works normal again.
Hope it may help you;
Regards;
VOTIT
If it is working fine and then shuts off and gets hot in just a matter of seconds then you are in the process of frying your amp. Disconnect all speakers and recheck your speaker load. Try only one speaker on one channel and then one on the other channel at first. Or better still, while you have all the speakers removed, try listening on headphones and see what happens. It sounds like you have seriously overloaded your output transistors with the wrong speaker configuration. Good luck.
