Master warning light and check engine light are on. How can I clear these?
I had the same problem. I unplugged the relays from the fuse/relay box under the bonnet. (Top left side) and replaced them. The problem disappeared. (2001 Prius 109,000 miles)
SOURCE: Toyota Prius 2001 Warning Light With Exclamation Mark on a car.
I had the same problem. I removed the relays from the fusebox under the bonnet/hood (top left side) and then replaced them. All working OK now. Sometimes I have had a problem when I start the car (especially after rainy day) the petrol engine immediately dies and I can only drive in electric. I have found that if I turn the ignition off and then restart it and immediately pump the accelerator it makes the engine run OK. Hope this helps.
SOURCE: toyota 2001 prius hybrid- warning signs
your owners manual should show all of the symbols and what they mean.I tried to get one to look at it but no luck...they should be in the manual though
SOURCE: 2005 toyota tacoma check engine light
pull the E.F.I. fuse located under the hood on the drivers side, if there is more than 1 efi fuse pull them both along with the E.T.C.S. fuse (if there is one) for 1 minute or so. That should do it
SOURCE: replacing a Ac Heater Blower Motor in a 2005
if youre sure that its the blower motor.......then HANG ON......cuz HERE WE GO!!!! k....open the passenger front door....get on your knees.....and look BELOOOWW the glovebox...there should be a black plastic cover...more than likely...that ya have to remove....after that....you can see your blower motor...should have three screws...maybe one more....and it will be released from the evap box....you then have an electrical pigtail connector you have to release and VIOLA!!!!!! there's your blower motor in your hands......install is opposite of reverse.....yeah I know that your knees hurt right now.....but...HOPE I HELPED!!!!!
