System stays on can not turn off can not access menu can not play or use the system is on and just say philips there is a cd in and can not eject how much would this cost to repair i think it needs a new hard drive? regards simon
SOURCE: aCER HARD DRIVE CRASH
you can easily buy a new HDD at buy.com or newegg.com but checking the old one and installing the new one are a little harder. The drive is simply a small SATA drive and can be plugged into any newer PC. Techs use a USB adapter, but if you know something about it, installing a drive isn't that hard. You may need to enable in in BIOS though.
Installing a new one is a simple matter, but then you have to install windows, which means you'll have to boot from the CD [and HAVE a windows install CD].
Good luck either way.
SOURCE: Philips SCB5265 DVD/CDRW drive only reads CDs but not DVDs
Take a can of air and blow it on the laser then try to see if it will read both cd's and dvd's. If it doesn't read one or the other then the dvd-rw would need to be replaced.
it means that your dvd lens is already damage. change your dvd player.
SOURCE: PHILIPS CDRW/DVD SCB5265 ATA Device cannot play most DVDs
I'm guessing you may have locked the DVD region. If you right-click on the device in Device Manager and click the Region tab, does it say 0 changes available? Acer won't fix this, and claim you have to replace the drive. Can't find a firmware flash for this drive online, will post back here if successful!
SOURCE: Philips External hard drive not connecting
Try connecting it to a different usb port. plugging out without first stopping the usb device must have the device settings on that port.
hi thanx for your comment but its not a pc/laptop its a music staion which can store 2500 songs
NO!!!!!!
