Red light flashes 3 times and tv dont come on
SOURCE: I have a LG 50PC3D when I try to turn on the TV the green light
This is a common problem.i recomend using your warranty if it still applies.if not, try hooking it up to a playstation and play with it.
SOURCE: TV will not power on.
The clicking you hear is a relay that connects,
then disconnects the AC to prevent fire or further damage.
If it just fails to turn on, the main power supply is probably at
fault and without some technical background and a couple of test instruments,
you will not be able to do the repair yourself.
What
you can do though is; unplug the set, let it stand overnight or at least
several hours, remove the back panel and look for a separate board with mostly
larger components on it; it will have a ferrite core transformer on it and
several larger capacitors which are cylindrical and mounted vertically to the
board.
Before touching anything inside, especially on that board,
allow several hours to be safe since the larger capacitors can hold a painful
voltage charge for some hours.
There are likely two power supplies, a main (larger) and possibly a separate supply for the plasma display.
Without inspecting your set it is difficult to determine which may have failed since the high voltage supply may use an output from the main supply.
If you see signs of overheating such as discoloration of
the board material, it may not be repairable but if you can find a part number
on the board, you might be able to buy the power supply and install it
yourself.
If there are no signs of heat damage to the board, there
may be companies offering to repair it as a subassembly instead of repairing
the whole set which could be much more expensive.
If
you choose to replace it or have it done, the power supply still may not be at fault since most
are capable of switching on and off if a downstream problem is causing an
overload.
Not easy to diagnose without having made a few measurements first.
Testimonial: "Thank you for the insight, I will follow your suggestions and see where the path leads!"
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: when i turn tv on green light blinks two or 3
We need to know what make and model to accurately answer this question, but if you have a Sony, here is the information -
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks.
Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
One blink - not used for the self-diagnosis
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
SOURCE: My LG 50PC5D has a hard time turning on. when
It seems issue with power supply board and most probably few electrolytic capacitors are dried up and causing problem.
Qualified local tv repairman visual check is needed to confirm the reason of problem as he will test/ check output volts of power supply.
If this tv is 3-4 years old then problem would be in power supply board as mentioned above.
Let me know if you have additional question.
Thanks.
Hello, a 3 times blink code could either be a power supply issue or a bad Y-sustain board. did the picture drag or slow to view picture before this happened? Let me know. thanks, Terry
