Frigidaire Master
- Posted on Oct 03, 2012
Re: how to remove the front of a ftat top range
See this guide and fix it. God bless you
Instructions
Disconnect the power to the stove by turning off the breaker
in your fuse box. Test the stove to ensure that power has been
disconnected by turning on a working burner and making sure it does not
get hot.
Open the oven door.
Remove the two bolts from the underside of the front of the cooktop, located just above the door jam, facing upwards.
Lift the entire cooktop to access the burners, which are attached to the bottom of the cooktop.
5
Remove the two screws from the brackets that secure the burner that you would like to remove, then remove that burner.
6
Disconnect the wires connected to the original burner, then
plug them into the new burner. The wires can be removed by simply
pulling them out of the terminals. Be sure to mark which wires go to
which terminal.
7
Align the grooves on the top of the new burner with the
grooves on the bottom of the glass cooktop, then secure the new burner
using the brackets and screws that you originally removed.
8
Lower the cooktop, then re-secure it with the two bolts that were removed from the bottom. Close the oven door.
9
Restore power to the stove to complete the installation.
