Turning corner or stop, engine dosent quit but does not run for a few seconds
SOURCE: Engine starves for fuel after running about 50 miles or so...
Has Neon do same, I ran fuel at low level, on hot day, ran engine until it started to act up & threw a fuel pressure gauge on it. Was at approx 5 psi. Cold next morning, 48-50 psi. Always hot day about 30-40 miles into work in morning, o.k. Sit in hot sun all day & would happen 3-4 times on way home. Sit and let cool, 20 minutes or so & go again for a while. Cool day, no problem. Change pump I would.
SOURCE: 2005 Chrysler 300 hemi. Engine quit going down
The fuel pump is a good place to start since I doubt if the timing belt has broken in a vehicle this new unless you have been racing it. Yes, the pump is submerged in the tank. It could also be the fuel filter and that should be located under the passenger side of the vehicle near the gas tank itself.
